36 Northern Bay compared to 36 Jarvis Newman
charlesosgood
Veazie, Maine
none, but looking
For extended cruising, which is the better hull? Looking for comments on motion at sea, room for storage, design, quality, efficiency under power, etc.
Thanks.
FVSD
Biddeford, Maine
The NB is going to push easier and should have more room. Most cruising Newmans are older highly finished heavy boats. My guess is a well maintained Newman can be a very good value if you don't mind a 12-15knt cruise.
Charles,Alot of the old Jarvis Newman boats were not built with high race type speeds in mind....most had small power by todays standards..having 3 to 1 ratio (length to width).they push along easy.....but it like comparing apples to oranges....Newman.... old design .......Northern bay ...new design
charlesosgood
Veazie, Maine
none, but looking
FVSD and MDI45- thanks to both of you for your comments. The JN is a bit narrower so I guess that explains the volume advantage of the NB. The JN I'm looking at is in Md and was repowered with a Yanmar 370. Seems like a good match up. The NB I'm looking at only has a JD 6068 220hp, but the owner says it cruises at 12-14, which is OK with me- former sailer. The JN will probably have a 14-15 kt cruising speed. I wonder about which one will be more fuel efficient- I would think the NB. Looking at the NB again this weekend. Thanks again.
FVSD
Biddeford, Maine
I like the idea of sub 300 hp NB36, long range and no cavitation issues with high HP. Perfect for a former sailor
Correct me if I am wrong but isn’t the JN a built down hull and the NB a skeg design?
I think for just cruising @ 15 of less I would opt for the JN. Plus Builtdown boats have more room underdeck. Lastly a good builtdown hull is the most neutral in all sea conditions.
Hard core fast running offshore fishing I would take the NB. Great fishing platform. Good in all seas at speed.
Mid-coast Maine
Jarvis Newman 36
In comparing the 2 boats you mention check the engine specs I am not an expert but I believe the JD may be more fuel efficient. The boat in Maryland looks nice, it has been on the market a while. Not sure what you are looking for but there is a jn 36 for sale at Pendleton yacht yard that looks real nice. 2 others if you are interested. 1 at classic boat shop. Fly bridge looks very nice and well maintained. Also Newman and Gray have a hull and a 350 yanmar package and will build to your specs. Pendleton, Classic Boat Shop, and Newman and Gray are all terrific shops. Good luck and happy hunting.
