- Sep 1, 2011
- Boat Make
I cant believe they use the hull and bulkheads as part of the fuel tanks.The only place I have seen that is on some PEI novi boats.
Sannitation hose for the raw water intake hose to the sea strainer?
The intergral tanks of Tony's that I know of have excellent history on them. I would take those anyday over the my H and H aluminium tanks. Leak prone hatches( we've added additional gasketing but they still leak) that allow seawater to drain onto and around the tanks, and then drain along the main stringer into the engine room bilge . We couldn't figure out why the engine room float switch kept turning on. Couldn't believe it until we tested it with the freshwater dock hose . Saltwater is the more corrosive element than Diesel fuel/oil
My guess is that won't pass a cummins seatrial..
H&H aluminum tanks?
Do you mean H&H in Salem, MA?
Not H&H Marine Stueben Maine as in the boat builders?
H&H builds boat with their own fiberglass tanks.
H and H Marine in Stueben
