Built right, she will fly
With 670 hp Emme has a 30 mph cruise at 2000 rpm sipping 24 gph and tops out at 36 mph WOT.
Boat weighed in around 24,000 lbs - not what I would consider a lightweight.
Has an insulated tuna hold under the deck, under deck live well and under deck dry storage area, shaft alley with dual element Racors and enough room to put a chair down there to fiddle with the transmission. Oh and 500+ gallons of fuel too. Did I mention the 6kw generator, because that is in there as well. Then if you step into the main salon, you will find all the batteries (2 8-D's for the engine and 4 6-volt batteries in series and paralleled for the house), 50 gallon fresh water tank, hot water heater, waste tank, 24 gallon hydraulic tank, all the pumps for various things - head, tuna hold, live well, potable water, salt water wash down, etc, the through-hull beamed transducers, engine room cameras and two glorious catwalks so you can access everything down there. Oh, also an engine with its dual exhaust. Want two guys under the deck working on things? Not a problem, plenty of room.
Topside there's the air conditioner, helm, settee, bait/tackle station, flip-down 20" flat screen television and the dash in all its glory with built-in flush mounted electronics. Forward there is the 4.1 cubic foot refrigerator/freezer, 3000 watt inverter/charger, bulkhead mounted head, enclosed shower, twin berths that take mattresses straight from the furniture store, hanging locker, galley, bow thruster, 19" flat screen television, anchor locker and the 40,000 btu heater.
Guess what I'm saying is there is a little bit of room in the ol' girl.
Here is the full list of goodies for those interested:
Emme
Northern Bay 38
Cummins QSM11 670 hp @ 2300
Electronic ZF 325A 1.79:1
28x32 4 Blade
30 mph cruise
36 mph max speed
Fuel Capacity: 500 Gallons
Dual 6" Exhaust
Airflow Restriction: 0%
Exhaust Backpressure: 0%
Time from Searsport, ME to Montauk, Ny : 11.5 hrs
Sportfish
Solid Glass Hull
Balsa Core Top
Full Height Balsa Core Stringers
Custom Non-skid pattern
Stainless Steel Hardware
Dual Steering Station
Autopilot
40' Removable Green Stick
Hydraulic Drum Reel
14" Hydraulic Hauler
Custom Stainless Steel Extendable Davit
Custom Power Coated Aluminum Mast
6kw Onan Generator
4kw Open Array Furuno Radar
6100i Northstar
Furuno Loran
Furuno Fish Finders
Dual VHF
ACR Spotlight
Dual Air Trumpets 141db
PA/Fog Horn
Sirius Satellite Radio
KVH Satellite Television
Satellite Telephone
19" Flat Screen Television
20" Flip-Down Flat Screen Television
Kenwood DVD Stereo
Stainless Steel Microwave/Toaster
4.1 cu/ft Refer/Freezer
Tuna Hold with Macerator
Live Well with Flood Pump and Macerator
Below Deck Storage Area
Strong Dripless Shaft Seal
Strong Dripless Rudder Seal
Custom Stainless Steel Rudder
Stainless Steel Shaft Razor
50 Gal. Fresh Water Tank
Aluminum Framed Limo Glass Windows
Custom Sliding Door Starboard Side
Custom Sliding Door Winterback
Removable Transom Door
8-Person Life Raft
SidePower Bow Thruster
Tecma Evolution Head
ElectoSan Waste Treatment System
16,000 btu Marvair Air Conditioner
40,000 btu Heater
QL Water Heater
80 psi Washdown System
Power Steering
Dual Bunks Forward
Enclosed Head/Shower
EuroTouch LED Red/White Cabin Lights
3,000 ProSine Inverter/Charger
Halogen Deck/Flood Lights
LED Navigation Lights
LED Ambiance Exterior Lights
LED Ambiance Interior Lights
Xenon Underwater Lights
Capac Galvanic System
Fabric Hull Covering Forward
Carpeted Interior
Custom Removable Salon Floor Covering
Bait Rigging Table w/ Wet Sink
Hanging Locker Forward
Aluminum/Stainless Steel Deck Hatches
Headliner
Custom Dash With Inlaid Electronics
DeepLuster Dash Finish
Custom stained Interior
Curved Furnishings
TriCel Deck
TriCel Winterback
Media Center Ports
Custom Cedrela Trim
Engine Room Cameras
Engine Room Lights
Access/Inspection Hatches Below Deck
Cockpit Controled 21' Outriggers
