42 oem
www.woundupmarine.com
St Augustine, Florida
Jack
2 Home made skiffs
Nice looking 42. What does she have for power? How many ponies required to push at 15kt cruise for a lightly loaded cruiser? No generator, no flybridge, 400-500 fuel, 100 water and basic accomodations, galley. Same house you show here except maybe 3' longer.
Catarina had a 3406 Cat producing 540 hp with a remote mounted heat exchanger that required 27 gallons of coolant. She did 22knots weighing in at 26,000 lbs.
So with todays power and laminate schedules the weight should go down and the horsepower requirements be lower as well. We had another 42 that went to Portugal, she had a detuned 3306 - taking it from 350 hp down to a paltry 195 hp. She did 16 knots but she was tied up at 1900 rpm. Probably 400-500 since thats where most manufacturers are focusing these days, unless you go to much bigger displacements but it never hurts to have a little more. That QSM-11 would slip inside very nicely and then you'd have 670 hp at your disposal and be able to boogie boogie boogie past all the other guys doing 15 knots when you're done idling around.
Something that turns slow and produces torque coupled to a gear that gets the shaft rpm in the sweet spot, that is what I'd want in my own boat.
Jack
2 Home made skiffs
I remember when "Jake & Josephine" was new. I used to see it all over Hull, Nantasket roads and in the bay. I didn't know it was new at the time, but she looked pretty!!
I don't think BHM ever made a 42, did they? The 39 was a nice tank though.
