4LH mixer
Discussion in 'Downeast Engine Room' started by 2na, Jun 8, 2019.
  1. 2na
    2na Member
    Jan 14, 2013
    57
    6
    Hi Folks,
    My mixer separated from the turbo assembly. It looks like the lower flange has rusted off. There should be a flange on the lower part correct? Is the flange am integral part of the unit or if there’s a sub assembly.
    My owners manual does not have a parts diagram & I can’t seem to find the part#. Can the lower Part be ordered separately or the mixer and turbo will need to be replace?
    Any help is greatly appreciated.
    Alan
    2na,
  2. WoundUpMarine
    WoundUpMarine Captain
    3,486
    1,634
    Boothbay, Maine
    26 Duffy, 14 Holland
    It looks like you have a 90degree riser before it goes into your water mixer. Yes, that flange is an integral part of the piece it rusted off you, you'll have to source a new one.
  3. ThePartsGuy
    ThePartsGuy Senior Member
    Feb 11, 2018
    121
    PARTS PROFESSIONAL
    NEWBURYPORT MA
    EXHAUST ELBOW BEND W/INSULATING COVER = PN 119175-13200 - $844.50
    V-CLAMP = PN 119773-13300 - $35.02 ea
    FLANGE GASKET = PN 119773-13250 - $4.95 ea
  4. djmarchand
    djmarchand Captain
    Jul 24, 2012
    556
    198
    Retired engineer
    Atlas Pompano 23 outboard
    The real question is why did it rust off? Look inside the turbo throat. Do you see a rough, corroded surface, maybe with some yellow specs. If you do that is corrosion and rust on the turbo throat almost certainly caused by water getting up into your exhaust system.
    Over time it will destroy the turbo. The fix is to redesign the exhaust with a riser with spill over point at least 12" above the water line. That is difficult to achieve on a downeaster without an engine box.
    Kailua Kid and ThePartsGuy like this.
  5. ThePartsGuy
    Feb 11, 2018
    121
    PARTS PROFESSIONAL
    NEWBURYPORT MA
    We've employed a surge tube to help with that. I think it was in a Fortier F26. Not a perfect fix but it does help. You are right it seems the motors get mounted low in several different hull types and the turbo life suffers.
  6. 2na
    2na Member
    Jan 14, 2013
    57
    6
    Thank you! Much appreciated.
    2na,
  7. 2na
    2na Member
    Jan 14, 2013
    57
    6
    Thanks! I will look into that.
    2na,
  8. southshore30
    southshore30 Senior Member
    Feb 22, 2012
    330
    147
    firefighter/EMT
    Cape Cod,MA
    Calvin Beal/Southshore 30
    Check out Marine Manifold inc in Long Island. Had them build one for me years ago for less than that. Inflation may play a part in a new price but it’s all stainless and designed right and mines still all good. Comes with a heat blanket too
    Kailua Kid likes this.
  9. tailhook
    tailhook Captain
    Oct 15, 2011
    1,068
    363
    buzzards bay
    31 JC
    HDI marine they have make stainless units cheap
  10. 2na
    2na Member
    Jan 14, 2013
    57
    6
    Thanks all. Bought the HDI unit
    2na,
  11. 2na
    2na Member
    Jan 14, 2013
    57
    6
    2na,
    tailhook likes this.
  12. WoundUpMarine
    3,486
    1,634
    Boothbay, Maine
    HDI is great, I bought a stainless unit for the little volvo, matched right up.
