- Jan 1, 2012
- Location
- Boothbay, Me
- First Name
- John
- Boat Make
- 26' Duffy, 23' Seaway, 14' Holland
well attacked my project of changing the exhaust manifold on my engine today. the bolts attaching the exhaust manifold were totally wasted so i had to sawzall off the flanges and then grind the bolts off. the turbo was all kinds of wastes, chipped at least a millimeter of rust off the housing, and the leading edge of the compressor wheel looks horrible as well. figured while i was at it would do as much other works as i could. the heat exchanger, aftercooler, and gear cooler are all going to get acid washed and pressure tested. putting new hoses, belts and a new raw water pump on. tomorrow i gotta clean the engine up and try and paint it as best i can, then clean all over the bilges as they are disgusting. there is a picture of the "air filter" too. its a mesh filter with a shop vac filter on it, and as it rusted all that crap went through the turbo. most of the engine should be back together by the end of the week, hopefully the turbo doesn't take too long to get back together.
headed down to hamiltons tomorrow to get a few anchor deck haches and some other goodies to do a few fun projects as well
