Ablative Antifouling Paint Recommendations
JPO
Yarmouth, Maine
AJ 28
I have been using Pettit Ultima SSA for the last 4 years and it has been discontinued.
Worked well and have just touch up the waterline and spots that are warn thru.
Do not want to go with a hard paint that builds up.
What do your guys recommend?
Hydrocoat by Pettit has been great if you use a foam roller (short nap) and go thin coats.
JPO
Yarmouth, Maine
AJ 28
Can I use the Micron CSC over the Pettit Ultima, Both solvent base.
I am going to sand lightly to clean it up but not going to take it all off.
Edit: Interlux site shows it is compatible, just wash and apply.
Going with Micron CSC.
JPO
Yarmouth, Maine
AJ 28
Thanks for all of the suggestions and info, really appreciate it.
ThePartsGuy
NEWBURYPORT MA
www.merri-maryachtbasin.com
BILLY
I have had good results with Micron Extra.
I use a very short nap roller and I thin it with Brush Ease.
Buy up what you can now. Mircon Extra is going away. The Biolux Interlux is using is NLA and they have to get a new EPA registration for the new soft/slime protection agent (Biolux) they are going to be using which will take a little time.
Also we have been warned by most all of the paint companies the color Green is going to be like toilet paper in the beginning of the pandemic!!
osprey47
Annapolis, MD
Joe
BHM 36 w/ Yanmar 6LYA-STE
Had our hull powder blasted down to the barrier coat. In past used Micron CSC. Switched to Pettit Hydrocoat. Don't miss the solvent fumes given off by Micron. Definitely use 3/16" roller brushes. The Micron takes a bit less effort to roll on (thin nape on the roller?) Overall, good coverage -- two coats black on red. Will see how it performs -- how clean is boat in fall haul-out and how much retouch is needed before 2022 spring launch. It is not cheap.
Genius
32 Morse Cove
I never thought Micron CSC had bad fumes. Micron Extra....oh boy is that bado_O
casey87
Have had good luck with hydrocoat sr, friends use micron csc/extra with good results
Bern
Portland, ME
Muscle Ridge 28
I use CSC, where I am, good current, I thin +/- 1/2 to 3/4 cup to a gallon. Light sand every year, 80% percent of the surface, almost no build in last three seasons.
southshore30
Cape Cod,MA
36 Northern Bay
