Adding 12v Accessory with Ignition Switched Power
Discussion in 'Marine Electrical / Electronics' started by ArchHibb, Jan 6, 2019.
  1. ArchHibb
    ArchHibb Captain
    Aug 31, 2013
    744
    534
    Architect
    Marblehead
    Five Islands 35 w/Cat 3116
    I want to add a 12v accessory with on/off power controlled by the ignition. I realize there's a million different ways to wire boats, but usually the engine start circuit is separate from the main DC panel, so I supsect the engine/starter circuit is the only one that is controlled by the ignition key.
    Can I connect a relay to the on/off side of the ignition key and use that to control a separate 12v circuit?
  2. djmarchand
    djmarchand Senior Member
    Jul 24, 2012
    457
    128
    Retird engineer
    Atlas Pompano 23 outboard
    Yes, no problem doing what you propose.
    ArchHibb likes this.
  3. captjohn
    captjohn Captain
    Apr 12, 2013
    545
    173
    Seaford, NY
    Henriques
    Just make sure the load you are adding isn't too much for the ignition switch. If it is, try a switch with a higher current rating.
  4. Keelboater
    Keelboater Captain
    4,406
    2,269
    [​IMG]
    Something like this perhaps? Current does not flow through the switch so acceptable load depends on relay and wire size.
    ArchHibb and Genius like this.
  5. ArchHibb
    ArchHibb Captain
    Aug 31, 2013
    744
    534
    Architect
    Marblehead
    ^That’s what I’m thinking Keelboater, thanks! That way the accessory circuit is isolated from the ignition key circuit and has its own circuit breaker protection.
    Is this how you are wiring your Aqualarms?
    captjohn likes this.
  6. Keelboater
    Keelboater Captain
    4,406
    2,269
    The alarms are very low draw so it's not necessary to go this route. Some of the installation is not even tied into the ignition and provides 24/7 coverage.
