Saltydoc58
- Oct 8, 2020
- Location
- Lloyd Neck, NY
- First Name
- Robert
- Boat Make
- Ellis 28 Yanmar 6LPA STP 315HP, Parker 1801 Yamaha F115
Planning to add/build a seating storage bench to the port cockpit to better suit our needs.
The bench will be "under the hood" and not directly exposed and will measure approximately 28" wide and 68" in length.(Wider or longer not an option)
For early planning purposes:
To keep in budget and to my skill set more toward wood- I was considering marine ply with teak or cherry trim.
What size plywood-1/2 or 3/4"?
Would you seal or epoxy the wood prior to assembly and final paint job?
Paint with Awlgrip or just exterior marine paint?
Brass screws?
Just getting thoughts together for with this project thanks.
Brass screws?
