unclefish
I need to check the alignment of the shaft to the trans. When I did my parents boat the shaft where it came through hull was close to trans I did not have alot of flex on a 3" shaft. I did use the feeler gauge to do that boat. This MC 32 must have 4 ft to trans. When I get bolts out am I going to see this shaft go down alot?
Should I just go up and down and side to side a and try to find the sweet spot and block it?
The prop is off the boat right now will that make a difference to?
Boat does have a drippless to?
Thanks for help????
Thanks for help????
