8943post
In the process of changing the engine mounted secondary Fuel filter FF5488, can't find anyway to fit the small rubber washer that comes with the filter. So I figured they use this filter on other motors and that's why it's there...then I looked in the drain pan and saw another one that must've come off the old filter?
Where does the rubber gasket go? Too big to slide onto the threaded neck.
