antifreeze drain on JD 6068
I can't for the life of me find the petcock to drain the coolant down on my engine ?? Where is it ?? Want to clean the heat ex & aftercooler before i pickle the engine for the winter.
Pedlyr
Southern RI
There should be a plug on the side of the coolant pump. Or better yet on the inlet housing attached to the pump. Usually somewhere in that area is where I do it on the newer models.
Older ones have a block plug behind the injection pump. At least the smaller ones.
sevenjohn
groveland
novi
steve,
my jd 265 hp 6068 has a petcock drain in front of the starter in the block on the port side of the motor.
