Batteries
Pitou
Cape Ann
Kevin
'06 Albin 31 TE
I also have 2 switches. One for DC power connected or seperated to the 2 batteries and an inverter / charger switch connected or separating the 2 batteries.
Really confused.
I guess I could use the dc switch and select starting battery and alternator will charge that battery while underway? And when I anchor , shut the starting battery bank off ,
put on inverter on ac house battery, and select that same bank for DC devices.? But again when I use the generator to run microwave will it also be charging the dedicated house battery which I don't want to over charge.
Amazing how complicated this .
Thanks for your help if you can give me any .
Do you have a switch/breaker on your panel that says Charger? That's how I am wired. If the switch is not turned on the charger aspect is off weather I am on generator or Shore power.
When my engine is running the alternator charges the start battery and the house and generator battery through an Blue Sea ACR .. Blue Sea 7610 120 Amp Si-Series Automatic Charging Relay
Genius
32 Morse Cove
what does your "charger" breaker do? How does that control the "charger". What board is it on, the AC or DC board?
Pitou
Cape Ann
Kevin
'06 Albin 31 TE
My charger breaker is on the AC panel and turns the charger portion ON or OFF.
Genius
32 Morse Cove
Are you sure it doesn't turn a charger on. May have nothing to do with your inverter/charger if you have one. Do you? Maybe it's just an inverter you have.
Pitou
Cape Ann
Kevin
'06 Albin 31 TE
I have the Xantrex Freedom XC Pro Marine Inverter/Charger .. 3000 watt inverter/150 amp charger. I have it set up to just charge my house bank (6 - 6 volt golf cart batteries) and have a 2nd charger at 60 amps to charge my start bank of 2 - group 31 starting batteries and genset starting battery. Both chargers are separately switched on the AC panel.
Inverter Charger | Freedom XC PRO Marine Inverter/Charger | Xantrex
05bill
cape cod
rp, willis beal
I dont have a separate switch. When generator power or shore power is applied a lite on inverter/charger says outside source,and this is where I am contused, the outside source now powers all the ac stuff through inverter/charger , I get that. However is the outside source also charging the battery , and if so, does the inverter/charger know when to stop charging the battery so it doesnt over charge it ? I am going to assume it does know, but I hate assumptions !!!!!
Thanks for all the help, believe it or not it helped !!!
05Bill
Genius
32 Morse Cove
I read/skimmed the manual for the charger, didn't see how to control the charger or information on how the charger operates. You'll have to elaborate on how it's wired.
Genius
32 Morse Cove
05Bill
Usually the chargers are pretty smart. If you click on Kevin's link, you can read how his inverter/charger controls charge voltage. I don't think you have to worry about over charging your batteries.
05bill
cape cod
rp, willis beal
Thank you Genius.
Now another question: I guess I don't know when to stop asking questions.
A deep cycle AGM ,AH 245 ,should NOT be charged by the engine alternator or is it ok to do so ? Yanmar/ Hitachi alternator .
Sorry for all the questions .
Thanks,
05 bill
Genius
32 Morse Cove
Thank you Genius.
Thanks,
05 bill
battery charging can really get very very technical, down to length of cable and how they are connected...But for most people and to generalize, you'll be ok. AGM's typically see charging voltages very very close to flooded lead acid batteries.
05bill
cape cod
rp, willis beal
When you read the literature it scares the heck out of you.
Thank you again ,don't want to ruin a 1000 dollar battery .
We will see if the AGM high ah is worth the money.
Thanks again
Pitou
Cape Ann
Kevin
'06 Albin 31 TE
The combo charger / inverter is controlled by a remote display panel that has keys on its face or controlled by Bluetooth that I haven't figured out yet.
The Inverter aspect can be set to "always on" which if no AC power is detected from Shore or generator then the automatic transfer switch provides inverted AC power to the boats AC panel or it can be set to "manual" which it only then supplies inverted AC panel when you want it .. that's the state that I use.
It's basically the two separate units (charger & inverter) built into one housing case and wired for inverted AC power out to the boat's AC panel through an automatic transfer switch and AC power in from the boat's AC panel supplying AC power to the charger aspect of the unit when on shore or generator power. Could you run the charger with inverted AC power? I would say yes, but never have or would as it would be self defeating using DC converted to AC to then recharge the DC bank .. kind of like chasing your tail.
I hope that makes some sense. Xantrex just came out with his unit this s;pring, so it's a fresh install and I'm still learning all of the ins and outs.
Genius
32 Morse Cove
Thanks. The only question I have, is how the charger is controlled. If I would guess, the remote display panel. But, from your comments, it doesn't appear so. You mentioned a breaker/switch on a panel that controls it. I just don't know how that would be wired.
Pitou
Cape Ann
Kevin
'06 Albin 31 TE
Wired right from the switched marked House Battery Charger on my AC panel directly to the AC in on the unit. When charging, the display unit displays battery voltage, amperage output and weather the charger is in bulk, absorption or float stage. The display can also be configured manually for equalization mode for flooded batteries.
The charger can be configured for Flooded, Gel, AGM or Lithium.
Genius
32 Morse Cove
what battery charger??? I understand you have two, an inverter/charger and a stand alone charger. I feel like we are going round and round.
EDIT: never mind, I think I understand now. There is an 120VAC load panel from the inverter/charger and a 120VAC supply panel. I've never come across this.
Pitou
Cape Ann
Kevin
'06 Albin 31 TE
Sorry .. I should have posted that diagram earlier .. would have done a better job than me.
osprey47
Annapolis, MD
Joe
BHM 36 w/ Yanmar 6LYA-STE
Hi Joe,
You mentioned that your generator out put is lacking. One option that you have on many Yanmar‘s is to remove the electric air pre-heaters. This greatly reduces electric demand. I did this with my twin 6LY’s but only have 2 group 31’s hooked to each engine.
I see that you are in Annapolis, where did you get your alternator rebuilt?
Dave (also Annapolis, South River side)
Pasco's used to be in the strip mall near intersection or West St. and Rt. 2, but appear to have moved to 2039 Industrial Dr. off of Bestgate. Might want to call first. The lacking of output refers to the ability of an 80amp alternator to provide the wattage needed to charge my house battery bank efficiently. The Yanmar given the boat's weight (22Klbs w/ 1/2 fuel load) is a bit underpowered so bleeding off power for the alternator is not desirable. Repowering. No, not with an engine that has 1300 hours. Then again I have solar panels on the cabin-top.
05bill
cape cod
rp, willis beal
Well guys. Installed th AGM house battery. Went out for 24 hours. Battery powered refrigerator, a couple of lites ,charged cell phone. Never realized how much rifregerator used amp hours.
Anyway used generator to power microwave ,coffee pot. At the end of the 24 hours battery was down about 60 ,% Used generator through inverter to charge her.
Now seems to be operating how it should .
All I can say is I hope that AGM has much more cycles than open lead acid. We shall see .At the price it ought to last a lot a little long time !!!! We shalall
