backman
Going through my running gear this winter - engine alignment, replacing worn cutlass bearing, checking dripless, etc - everything came out.
This was prompted by the need to re-align the engine as well as deal with a visibly worn and misaligned aft cutlasss bearing. A quick check of engine alignment this summer showed it off by 60/1000".
The shaft had groove and wear on it at the aft cutlass bearing so it got sent out to H&H for repair along w. prop and coupling so everything gets refaced together.
To my surprise they found the 146 X 2.25" shaft 9/1000 out of true at the aft end, 8/1000 at the coupling and 6/1000 in the middle. Not a big deal for them to straighten while welding up the grooves in the shaft.
Questions:
Is this "normal" and expected for a 5 year old shaft w/ only 1000 hours on it?
What is the alignment tolerance for a 2.25" shaft in a 36' DE w/ 670 HP?
Questions:
