God forbid that they spend the $20bucks and twenty minutes to change it instead of adjusting their man bun for an hour.Like John said , if they are low like that make sure the line loops up high , or has anti siphon etc , I was moving a sailboat and the bilge hose had been shortened many times so on a starboard tack it would back and fill with water , quite exciting at night in a strange boat
I like them on the helm side of a lobster boat. That way I can keep an eye out as to when the pump comes on and what’s coming out. There can be Lots of important information coming out of the bilge. I want to see itLike em just under rubrail ahead of main bulkhead
This is why I’m moving it in the first place. It was at the transom and I like to be able to see itI like them on the helm side of a lobster boat. That way I can keep an eye out as to when the pump comes on and what’s coming out. There can be Lots of important information coming out of the bilge. I want to see it
For what it's worth, I recall some bilge pump install instructions call for a minimum of 12" above waterline for discharge outlet.
Same as all my dad’s lobster boats. Up high and visible. Doesn’t do well for a dockside princess though.I like them on the helm side of a lobster boat. That way I can keep an eye out as to when the pump comes on and what’s coming out. There can be Lots of important information coming out of the bilge. I want to see it
No because of the risk of exhaust gasses coming through the bilge pump plumbing.This is probably a dumb question, but could bilge water be sent out the exhaust along with the cooling water? As long as they don't feed back to each other? Anti-siphon / check valves?
My Laz pumps out at the tuna door ramp and is check valved.Good to see its actually going when you've been backing on a fish for a while and theres been a foot or so in the cockpit a few times.I ran my rear lazarette pumps (primary and secondary) to discharge underneath my gunwhale at transom....this way I always know when the pumps are going on. The switches with lights are great but they are 30 ft away at the helm. When I am in the cockpit I see the pumps come on and dump water onto the deck near the scupper. Some may disagree, but I will never not do this, I love the concept. Good luck.
Absolutely, One day the oil pressure sending unit cracked and oil was leaking into bilge. Having the discharge on side with helm where I was hauling gear, let me catch it quickly and shut things down. Quick tow in and fix and were back out hauling gear in the afternoon. Never want bilge discharge where I can't see them easilyI like them on the helm side of a lobster boat. That way I can keep an eye out as to when the pump comes on and what’s coming out. There can be Lots of important information coming out of the bilge. I want to see it
I had a nasty case out on Guam involving a boat that sank at the dock in the night. The bilge pump through-hull was located at the waterline, for cosmetic reasons. The in-line check valve failed when a small bit of bilge debris held the valve open after the pump cycled. A small wake introduced seawater. There was no anti-siphon loop. The boat sank before dawn. Constructive total loss. Hundreds of thousands of dollars. The owner was fined under the OPA ‘90 Clean Water Act over the resulting oil and diesel discharge into the harbor. Huge fine. Nasty, nasty.Absolutely, One day the oil pressure sending unit cracked and oil was leaking into bilge. Having the discharge on side with helm where I was hauling gear, let me catch it quickly and shut things down. Quick tow in and fix and were back out hauling gear in the afternoon. Never want bilge discharge where I can't see them easily
I like that you can see the water coming out if you are at the helmLike em just under rubrail ahead of main bulkhead
