Bilge venting ? Pics anyone?
Wondering what configurations are out there for through deck bilge ventilation.. AKsteve showed me his. Seeing what my options were.. Pics anyone?
venting
Bill. are you referring to venting as in a power vent for gas vapors or passive venting to cut down on moisture and condensation
RyanCT
Long Island, NY
dehumidifier?
If trying to combat moisture; could some type of dehumidifier be used while it sits at the dock w/ shore power?
Was curious if this has been done or considered.
DIRTY RIGGERS
USA
A 60 watt bulb under the engine box will keep the bilge very dry and usually warm enough to not have to winterize. I leave mine on when the boat is hooked up to shore power and my engines look very clean and rust free with over 23 years of service. Of course if the temps drop way below 20* F for more than a couple of days then you might have to add a block heater to the motor to keep it warm enough unless the boat will be winterized.
Not sure what thread it was but someone recently post pics of an air chase he had added that let air in/out under the gunwale. Like a bump on the inside of the side of the boat that was open at the top but just under the side deck by an inch or 2.
I am thinking i might take one of these solar powered vents and set it up with a duct to constantly move some air from my bilge. Maybe even mount it on the side of the house? not sure how those are designed so vertical installation would probably not be best.
Seems like a relatively easy arrangement and I would rather have it ducted out than have the vent fan on or near the cockpit floor.
The lightbulb idea is good too but the bulbs can burn out and you need shore power. I like the idea of adding a little heat though.
roydawn
N. Ft. Myers Fl.
Sea Fox 256
I had 2 of those solar vents on my Grand Banks 42. One in the aft cabin blowing air IN, & one in the V Berth blowing air OUT. (Reverse blade on one) Worked great when on the hard or when boat was left unattended. Good positive air flow. Always wanted to add one to the bilge/engine room near the holding tank, but never got it done. Roy
Curmudgeon
I replaced the deck in my last boat and added air inlets in the stern corner where the side of the boat and transom meet that came up under they gunwale. So the engine drew air the length of the bilge. Bilges were always dry. Sorry no pics I dont own that boat anymore.
cb34
vent
Leaving the corners open works great, plus makes the deck easy to clean up.
Many thanks for the replys.. What I was talking about was the ventilation system that CB posted.. I will be copying that thank you..the way that my stringer system was designed, there is no ventilation at all on the pockets outboard of the hull stringers and the way that the deck stringers are supported (a angled 2x8) ontop of the hull stringer I think it lead to failure of the deck stringers and the deck to some extent. I'm finding out that my boat was a kit boat. If you look at BillDs stringers which are in excellent shape being an '89 boat.. It makes a difference .. I know this cause my stringers are 2x4s and BillDs are 2x6s( the way terry built them
Those corner pockets and a scupper style intake would be fine IMO. Especially if the boat lives on a mooring so wind is always blowing in.
Much better to have an inlet opposite the outlet to make some cross ventilation but anything is better than nothing.
Do you have anything forward?
