backman
I had a grand time removing my old holding tank, hoses and dead macerator pump this month. The toilet stays, everything Else is new, going back to the same locations.
the head is located where a head should be located , in the aft most starboard location in the cabin. The tank is located midships outside the outer stringer, it’s a 6’ hose run from toilet to tank and at least a 24” uphill run from toilet output to tank input.
Multiple questions :
1. Better locations in a DE for the holding tank than 6’ back and 2’ higher? is That normal? I have no space in the head itself for the tank.
2. My head always stank no matter what I did to treat it. When I removed the old tank i realized that it was bow high and with the drain fitting on the foreward eNd of the tank the last gallon always stayed and festered. Is there any reason why I can’t shim up the new tank so it’s aft high and all liquid would sit in the foreward part of the tank? My gut is telling me this is a really bad idea because then a partially full tank will always be putting liquid pressure against fitting to hose to hose to pump connection which over time could leak through the hose ends?
