CCV Filter Drain
casey87
My Yanmar 6yl has a Racor CCV filter added from previous owner, the drain that Racor says should go back to oil sump is capped. Its collecting oil which is going nowhere and fouling the filter prematurely ? I just noticed that a bit of oil was collecting on the air filter - the output of the filter flow tube comes out (I think stock yanmar has the CCV tube just coming to the air filter, my set up is same except it goes through filter first). I can take a picture of the set up if helps.
Has anyone set up a bottle or something for the filter to drain the oil back to? How long are you guys getting out of these filters?
Thanks!
Genius
32 Morse Cove
I have one on my Cummins 6BTA. I just have a hose to a plastic water bottle. Very little to no oil collects. Yes, I understand you can plumb it back into the sump. Unless I had copious amounts of oil I see no reason to. This way I can monitor it. So far I have 300 hours on mine. It has a tell tale that will indicate when the filter is in bypass. My plan is to use that or 500 hours.
captjohn
Seaford, NY
Henriques
In a nut shell, it's basically a crankcase vent system (PVC), kind of like you have in a car, with an oil vapor separator. The oil was originally intended to return to the oil sump. Personally, I would do what Genius did, I wouldn't want that dirty oil going back into my oil sump. Plugging it up probably causes the oil to back up in the tube, and clogs the filter.
Genius
32 Morse Cove
it's not a filter in the normal sense of a filter. It is a coalescing element. I don't believe that oil is any different than what is typically in the sump.
Boothbay, Maine
goody
Forked River,N.J.
Ellis 28 and Tripp Angler 22 C/C
I have one on mine it drains into plastic jar. I cut a hole in lid. It works
traditions
38 Holland
Side Note One should be very careful not to plug the flow thru a crank vent, it has been known to take out crank seals with increased base pressure.Make sure there are no low spots for oil to collect.
AGL
Martin
Custom
Small engines and gas auto engines use a check valve to maintain slight negative pressure in the crankcase. A check valve holds negative pressures of the fluctuations in crankcase pressures due to pistons moving. (less effective on multi-cylinder) My small Yanmar (non-turbo) didn't have a check valve between the valve cover and the intake, so I installed one.
So, I don't see how the systems in this thread achieve negative pressures. Why not?
Genius
32 Morse Cove
I've never heard about negative pressure cranckcases or the benefits of it. The open end of the system is to the intake which I imagine produces a slight vacuum. Your check valve may have something to do with carburetor engine / air regulated flow and don't understand the cross over to diesel engines. I do love how my 2 stroke snowmobile engine deals with blow by.....using reed valves to supercharge crankcase gases and a resonating exhaust chamber system to further supercharge the air fuel mixture.
AGL
Martin
Custom
Here are some links on negative crankcase pressures.
A diesel doesn't have manifold vacuum, and indeed, with a tubo you have the positive pressure, but you could at least get some negative pressure with a check valve to help remove moisture buildup and blow-by as I have done on my Yanmar. Without that we're no better off than historical systems Crankcase ventilation system - Wikipedia
Genius
32 Morse Cove
sorry, I don't believe it. Improved ring sealing? It started out as an emissions thing, that's all its about.
AGL
Martin
Custom
I agree with that, but it is a good idea to remove moisture and blow-by from the crankcase.
