cost to freshen up a 3208 cat? hours?
Badlatitude
CT
At what point would one consider either freshening up, new shortblock or a repower for a cat 3208TA 375hp in a down east boat?
I seem to come across a fair share of boats with what seems like very high hours to me. Going for big bucks.
Badlatitude
CT
Holy crap!
I know there is no rule of tumb but there has to be a general guideline no? Id hate to spend a huge amount of money then have to go for a repower etc.
31jcptown
Long Island NY
91 31 JC P-Town
3208
I have a 375 3208TA in my 31 JC and had 5,000 hours on it just pulled it last winter had heads shipped out new head gasket, Rear main seal, rebuilt trans all new hoses ,starter and new heat exchanger looks like new. only problems I ever had was fuel pump and 1 bad injector in those 5k hours. rebuild coast me a little over 4k
The 3208 are great motors. There is no rule of thumb on when to do a Freshen up. I would stay if you have a 3208 with 6,000 hours that has never been apart do the following:
Remove the heads & send the out. A head gasket failure on a 3208 is the kiss of death. By the time you realize the gasket is blown the block gets scared fro from the cross fire and she is toast. Head gasket replacement is very key on the 3208.
Short block itself. Leave the bearing pistons etc alone they will last for 12,000 +
Change the pan they rust out.
Heat exchanger clean out always a must
Badlatitude
CT
Thanks Larry thats the kind of info I was looking for.
MBILL
35 Duffy&Duffy
Larry's certainly correct.
Also, with non commercial diesels it's all about "marine age", not so much engine hours. Watch the aftercooler and the heat exchanger....
Parttime
Cat says the injectors should be changed every 2000 hrs. Didn't know that until I had a retired cat mechanic work on mine.
He also told me not to put the cat antifreeze in the 3208. Use a regular 50/50 mix with a regular rust inhibitor.
Every 2000 is the recommended. You can get double that life no problem. Antifreeze is very key us theirs it is the best. If you mix 50/50 Use Distilled Water. CAT also sells it premixed.
5akman
Chico CA/Kenai AK
www.alldrinsalmon.com
40' Snowball gillnetter
For really good info on the subject, join Boatdiesel.com for 25.00/yr. LOTS of great info on all marine diesels. Not trying to take business away from DE forum but the BD forum specializes in just marine diesels and I've found it worth the 25 bucks!
MASTERENEGADE
NORTHPORT
Had a DE, now 24' Privateer
Damn i almost had a heart attack reading this. My 3208t has 2800hrs on her and i have never done injectors. Then larry you chimed in and revived me.
Question whats the tell tale sign as to when its time to replace injectors?
googinhater
Gloucester mass
38 yb. f/v wildlife
I Always us cat antifreeze its great stuff have no problems and have over 16,000 no to and 12,000 on the third the cats like to run they hate to sit if you run them use cat antifreeze
Parttime
The way it was explained to me, the inhibitors in cat antifreeze don't do well in 3208 engines. There is a cat bulletin on the subject.
Just repeating what a 30 year retired cat mechanic told me.
