Ok i'm going to do my split house addition with plywood covered with fiberglass, my question is what is the correct way to do the edges of the plywood. Do i route/sand a radius on the edges and wrap a strip of mat around the edge and then cover the rest of the plywood with mat or do i leave the edges square and layup a narrow strip of mat on the flat edge and cut/grind it flush with the edge after it goes off/hardens then just butt up the mat covering the rest of the plywood. I'll be doing 2 coats of gelcote over the mat to finish things off. I only want to do this once so please set me straight on doing this the right way.
