Crusader 5.7 MPI 330 hp 2.52 gear in a 25 DE
Hello guys,
I've been doing some calculations on the 25 T Jason (Bill's new/used boat).
Not for Bill, just messing around in my head.
The prop aperture is 26.5" (26.5" X .85 = 22.50")
Looks to me the 25 T Jason hull can swing a 22" prop. Terry Jason confirmed this.
Terry stated when he was building the 25s years ago his choice of power was a 225 John Deere 6068T with a 2:1 gear swinging a 22X22 square prop.
I'm curious....do you guys think a 330 Crusader 5.7 MPI with a 2.52:1 gear can "swing" a 22X22 prop ?? Figure a 3000 rpm cruise, shaft speed = 1190
A 3200 rpm cruise shaft speed = 1270
Or with the limited torque of a gas 330 MPI are we talking a smaller wheel...maybe a 20" ???
Any thoughts ????
I think the boat would run well with that power. However a 22 X 22 would be a push. Most likely you would end up with a 22 X 20 or 22 X 19. Shaft size should be 1.5 minimum.
Hello guys,
Any thoughts ????
"Just messing around in my head"
1st time ?
:D
if it were me i'd put in the biggest gasser i could find/afford and wouldn't have to run the balls off it, but would have the speed/power if i needed it.
