fishybusiness
- Aug 21, 2013
- Location
- Humboldt County, Eureka
- Website
- www.northwindcharters.net
- Boat Make
- 35' RP
Greetings everyone, so I took my boat out today and when I reached 1600 rpm is started bellowing black smoke and wouldn't increase in RPM. I am going to check to see if I have a air leak on the pressure side if the turbo, and if that isn't the problem I am going to take the after cooler off to see if there are any obstructions. It has a new air cleaner so I am ruling that out. Any of you motor heads have any other ideas why this is happening? It runs smooth so I am just guessing that the injectors are ok, however I am going to run a can of injector cleaner thru her anyway if the above doesn't take care of the problem. Any other ideas on why this would be happening? Thanks in advance, Matt....
