Custom Stainless Bow Railing
Keelboater
Does the entire rail need to be replaced or can it be repaired? If it's stainless they can cut the damaged sections out, make new pieces, and blend the new welds so you never know it was damaged. I have made dozens of rails for Cape Dory back in the 1980's and have also repaired a few dozen more over the years, including my own projects. If you need the entire rail replaced it must be pretty bad. :-( Find out if it can be repaired before you spring for a complete railing job. Good luck!
If your rail was original from day one there is a very good chance Nautilus made the rail and have a pattern that will fit the boat exactly from when it was new or just all the other Duffys they have done. I know a guy that had one made and it fit like a glove without them ever seeing the boat.
