Cutting down a shaft
cb34
Anyone hear of cutting down the length of a shaft while still in boat?
Explain?
Cut the shaft in half and then splint it ?? :?:
Curious
It's called a "joke"
if you're going to do it in-boat do it on the area inside your coupling, you will have a shorter keyway and key. if you run a pin, you can re-drill that no problem, and for the set screw use a bushing to make the dimple.
