Deck repair
Dworks
Hampton,NH
Had a couple soft spots on floor thought I would just grind up the bad repair, job done.Pulled one piece ended up taking the whole floor up now I have to glass the whole floor, what would you guys recommend for glass mat or cloth and what weight also polyester resin or epoxy thanks.
Dworks,i would use two layers of 1.5 once mat and polyester resin..its old school but it works;)
GoodChance
SW Florida
If there are any "joints" between the newly replaced wood and the hull, you really should consider something with structural strength like 1708 biaxial. Polyester resin would be fine but epoxy would be better.
Tuna,did i add iam a commercial fishermen so i like to do things cheap!!and hundreds of lobster boats are built this way;)
