diesel gen set
rarel01
Looking for opinions as to what brand gen set in the 4.5 to 5.5 kw should we install in our boat. Any suggestions would be greatly appreciated. Thanks Bob
rarel01
Its for our 32 levy. If Bill sells them i would like to contact for pricing ect. Do you have experience with fisher panda, they seem pretty complicated. I was leaning towards northern lites orwesterbeke but am open to anyone with first hand experience.:)
The panda was a slick easy install. Had an external control box that is situated elsewhere from the engine portion. So you don't need a huge space, we hid the engine under the deck and the control box above it in the settee. A little water lift muffler with a vented loop and it was all done.
djmarchand
Atlas Pompano 23 outboard
I have two recommendations:
1. For a heavy duty, rock solid generator that will last almost forever (if used and maintained properly), buy a Northern Lights.
2. For a much lighter one at half the weight but fine for casual use, buy a NextGen.
I can't agree more.
Fischer Panda is an over engineered complicated unit. I knew a German that had one in his NB 36 and hated the thing.
Northern Lights might be more money but they are bullet proof
Northern Nights makes a great unit, I think it is well worth the money if it is going to get a lot of use.
MBILL
35 Duffy&Duffy
I have the Northern Lights genset in a 35 Duffy and it's been a very reliable unit.
Never "over crank" the engine if you've got a water lift muffler (I have one too). You can cause water to flow back to the engine and bad things happen...
rarel01
Guys, This has been fantastic! I was leaning towards northern lites or westerbeke. The mechanic at my marina did not have alot of good things to say about fisher panda. Thepoint is thst I am anticipating aproximately using the gen set 500 hrs or more a year. The exhaust limitations and over cranking could anyone eliborate on . The kind of $$$$$ we are talking i want to do it once do it right. Thanks again Bob
Cranking turns the engine over, which in turn rotates the impeller over to cool the engine as well as the exhaust. However while turning over the engine is not producing enough exhaust to displace and move the water being introduced to the exhaust stream from the impeller, letting it build up to potentially back-flow into the cylinder via the exhaust valve.
One of those "uh oh" moments
Moral of the story is, it it doesn't fire right over after the first few cranks close off the water intake and try again. This way you are not filling your lift muffler with water which will back up into your engine when it doesn't start and is full of water.
Check out nor pro also. 5 year 5000 hour warantee and there in ct.
Downeastless
We had a Northern Lights, bullet proof until it mysteriously had water damage. Sadly it got winterized/commissioned when I was oversea's so I can only imagine what was done.
Anyone have ball park pricing on these units?
