double anchor setup
Whatta Catch
Brooklyn, N.Y.
www.whattacatch.com
40' H and H, 31 JC and 25' Carolina Skiff
I want to add a double anchor set up to my existing pulpit. I already have the hydrolic hauler and all the hardware on the gunnel for two lines running towards the bow. I would only need a roller on the port side to guide the line to the port block. I want to take the pulpit off and have a welder weld a crossmember to the front of the pulpit so i can attach the blocks to. Any feedback will be appreciated from the guys that have them and the welders on this site.
eyschulman
seattle
That is a long unsuported sprit out there. Be carefull if you should have an anchor hang up when trying to break loose.
Whatta Catch
Brooklyn, N.Y.
www.whattacatch.com
Mike does your cross member go through the pulpit or is it welded on? Next windy day I would like to take a look since they are very similar.
