EL TORO
Bill_N
Eastern Ct
31' JC Rowdy Girl
Looks great! I did the keel fairing on my JC but didn’t extend the tube. I had to have my prop re-pitched afterwards but it was worth it. I gained some speed and it backs up a little better also.
hardcore1
moriches ny
I checked out what you did bill,. Looked good, glad it had positive affect on the boat. You would have to lengthen the shaft to extend the tube. Gives a little more clearance for the prop all around by doing so. She was turning a 23/23 dynaquad. The new wheel is 23/21 dqx. It will be interesting to see if there is any difference.
Bill_N
Eastern Ct
31' JC Rowdy Girl
I replaced the shaft when I got the boat so that wasn't an option for me. I'm sure you'll see an improvement but it will be hard to tell where it came from since you changed the prop at the same time. Post your numbers when you get her in the water and run her a bit.
hardcore1
moriches ny
My 1.2kw transducer was a little too large for the stock fairing. It did not read well above 8knots. Building a custom high speed fairing block
Scrib
Bob
Jarvis Newman 36
What did you paint the prop & rudder with?
