- Sep 1, 2011
- Boat Make
Engine placement in a downeast hull
Hello ALL,
I was reading/reviewing some older posts from noreast.com and this forum.
I came across "powderpro's" (Brian) great thread on building his 34 Calvin Beal with Cummins QSC 500 power.
The speed during seatrials for this 34 Calvin were impressive. Brian suggested in a post that "maybe" the placement on the QSC more aft in the hull than rountinely done in a 34 Calvin Beal "may have" helped with the seatrial speeds.
I also noticed in the seatrial pics and the video of the boat running that the "running attitude" of his build was relatively flat.
I've also read many posts by owners and builders that "many DE hulls do not like carrying weight forward. Holland's boat shop has built the 32 with v-drives placing the engine further back in the boat.
And we see many DE hulls with engines half in/half out of the forward cabin.
Many forum members (and me of course) are searching for the 28-32 ft DE boat that will cruise an easy 20-22 knots. We know Brian's 34 Calvin Beal could. I'm sure there's a 36 NB that can do 20-22 knots, John's 36 Flowers can.
Is it possible to gain speed in a DE hull by moving static (engine) weight to the aft of the boat?
Let's open the discusions !!!!!
Bill D
Saltwater Fishing Discussion Board Including Inshore Fishing, Offshore Fishing, Saltwater Fly Fishing and Kayak Fishing
Powderpro's post back in 2010
"Definitely a home run, although I'm not surprised with how light the boat is, how flat the stern is, and how much power the engine produces. That 8.3 Cummins has some serious power. I don't know what the weight of the boat is, but my dad and I were guessing around 14,500 pounds at sea trial. When loaded with fuel, gear, etc, probably about 17,500 pounds. I wish I knew what the weight was, but I don't know. What I do know is the boat jumps out of the water when you give it throttle.
One thing that is different on my boat than most other CB 34's is where we placed the motor. Calvin Beal Jr. suggested a 12'6" shaft length. I'm assuming most, if not all CB 34's have about that long of a shaft. I placed my engine farther aft with a total shaft length of 9'10". So my shaft is 2'8" (32") shorter than what is probably typical. I'm not saying that necessarily helped my numbers, but it may have. My dad and I believe in keeping weight out of the bow of the boat, and the engine is the heaviest single item in the boat, besides the fuel."
The CB 34 called SEACOCK participates in some of the lobster boat races. I think he told me that his engine produces around 540 hp, he has the same reduction as me (1.75:1) and the same or similar shaft length as mine does. He runs a 3 blade prop (mine is 4 blade) and I think he tops out at about 37-38 mph. His boat probably weighs about what mine does, but my cabin is taller and grabs a little more air.
This post edited by powderpro 10:13 PM 07/05/2010
Hello ALL,
Bill D
