Even though they aren't easy to track down I really like FW Murphy gauges. I have gotten my oil pressure one already for my Cummins 6CTA. The nice thing with the Murphy gauges is you can add alarms to just about anything with their switches...
I have to say the exhaust pyro for sure.
Also the loss of cooling water circuit is a must. Do you know how far you can actually make it with a sea cock closed? I do, bonehead move but it happens to the best. Now whenever I close the seacock to my engine I put my engine key on it. To many trips back and forth, long nights working sometimes you forget.
I am surprised that no one mentioned boost air pressure, its cheaper and easy to run. Of course you can get a pyro/boost together.
I'd really like to add a flowscan, have had three of them in the past...
I saw 1st hand what a Cummins 6BTA 370 looks like after running it @ 2200 rpm without raw water flowing through the engine for "reportedly" 5-10 mins.
Dock neighbor left the Charles River locks after 4th of July a few years ago.
Port engine seacock was closed. He was up in the marlin tower, (no alarms) took off with a line of boats heading north.
Guy in back of him noticed a funky plume out of the port side xhaust and race up next to him and waved something was up.
Owner slowed down to idle, engine temp was pegged @ 250F, alarm down below in the helm cabin was buzzing away.
Limped home, impeller cooked and the Cummins "off white paint" was roasted to a nice light dark brown. Not just around the turbo and bottom of the after cooler where it's normal but the whole engine!
Believe it or not the 370 had NO damage. ( I saw it, couldn't believe the engine was not damaged)
Local Cummins dealer came down, changed impeller, checked the engine over and repainted it back to "off white".
I've seen Murphy gauges used on coolant expansion tanks.
Important to note here is that when you lose raw water cooling to the engine you have a slight margin of time before a catastrophic overheat. The engine still has internal coolant flowing around.
Lose the internal engine anti-freeze coolant circulation from busted belt, frozen alternator bearing, blown coolant hose or busted clamp the engine burns up REAL FAST! particularly @ say 75% load cruise rpms.
FWIW
