engine thru hull
cb34
My engine thru hull has neither a scoop or a screen. My previous boats had the brass slotted scoop. Any concerns with water flow or possible clogging? thanks
If you don't want a screen on the outside like a South Bay strainer....you will need a sea water strainer in line...on the inside of the engine room....I like Groco products
cb34
water
Thanks MDI, boat has an inline. Just wondering about water flow without the scoop?
Powderpro
The Ocean
www.oneilboats.com
O'Neil
cb34- Are you building a 30 Calvin Beal? I have always used a scoop with slots and a sea water strainer. If it were me, I would be safe and get a scoop.
OLD BAY
Annapolis, Md
Eric
Shelter Island 38
Rambler
Rhode island
Wesmac
No scoop needed on an engine. Either a strainer on the outside of the hull with small holes or a Grocco type in line. If you use the in line, you still want to have a round strainer on the hull to keep any big stuff out.
cb34
round strainer
Anyone make a round strainer that inserts into the thru hull?
Rambler
Rhode island
Wesmac
You want a round strainer that goes over the intake. Go to Hamilton Marine and put in
STRAINER ROUND 8" PL BRZ 8" 103570
PLUMBING / STRAINER
Part#: BKA-00SR800
Get the right diameter to cover the intake. With this type of cover, you have to also have a Grocco type inline strainer.
