Fiberglass Mufflers
Pedlyr
Southern RI
Here at work I got a leaking fiberglass (Centak) exhaust. It is a wet exhaust with two 8" riser setups ( V 12 engine) ending one after the other at the front of the muffler. The muffler is off to one side right up over the reverse gear. Thing must be 3 or 4 feet in diameter.
The glass is delaminated on one of the riser tubes where a blue silicon coupling is clamped. Almost like a tear.
Is this worth fixing? Muffler body has some "plug" repairs from previous owner.
Sure is, sounds like a simple fix too
Might as well toss some glass on the inside of the tube as well, won't make much of a change at all as to the performance of everything and will take a bit of stress off of things
Good luck, those things are expensive
We usually reinforce the areas where clamps are going with either crush sleeves made from stainless steel or we just cut and slip in a piece of exhaust tubing on the inside of the piece we are clamping onto. Set the piece in a bit of hull and deck and glass the edges/seams. It's worked well for us.
