Fiberglass tank fill issue
Capt. Lou
Martha's Vineyard
54 Hatteras thinking of getting back into a small DE
I was attempting to screw in a reducer/gauge cap to my corroded tank fill bung. The old fill bung snapped off top of fiberglass tank. I believe it may have been attached using 5200. I am not familiar with the construction of fiberglass tanks but it seems mine had a large access on top and they embedded the fill bung into a square piece of unknown material and then screwed that down to the top of the fiberglass tank with plenty of adhesive and maybe even a coating on top of it. Anyway I was thinking I could just 5200 bung back on. Here are some photos that may help explain. Looking for ideas...thanks
Capt. Lou
Martha's Vineyard
And what I was trying to achieve was a visible gauge. Not sure I like the clear cover but I couldn't keep the screw in kind of hatch because there wasn't any Clarence above the cap
Here is one thought, if the pad or fiberglass is thick enough to get a few threads into it, clean up the opening and tap the top of the tank for the proper size nipple and then use a reducer and bushing to reduce it to the size of your gauge. And don't forget the proper joint compound for gas/diesel
traditions
38 Holland
That tank doesn't very thick.I would get a thick piece of glass,tap it with a 1 1/2 pipe tap,screw a 1 1/2 to 1 1/4 reducer into it and fasten it the same way the other one is.By using the reducer you have a set of good threads to screw some thing into.
I would clean both surfaces very good and epoxy it back on.
ToemanDoug
Capt. Lou, would you mind sharing some info about the gauge you have there? Brand, source of supply, anything to point me in the right direction.
I have been loking for a mechanical in tank gauge like that, but google has not been my friend.
Thanks, in advance.
Capt. Lou
Martha's Vineyard
Thanks, in advance.
I own gas stations and happened to be looking at a catalog for supplies and noticed they made mechanical gauges for standard 50 gal drum bungs. I have the same bungs as fuel tank tops. You have to specify tank depth when ordering i paid $25/ cap. they took 2 weeks to get. got them from Jme
Krueger Sentry Gauge Type L Gauges - L221
http://http://www.jmesales.com/catalog/productinfo.aspx?id=6118&cid=4325&skuid=KSL221&gclid=CJ-FgoTB1bYCFQsy4AodnxYAZg
Capt. Lou
Martha's Vineyard
My solution was I took a 1/4 inch piece of starboard and cut a hole and screwed and 5200 in the reducer cap. I then 4200 the hell out of the starboard plate and placed over old hole and screwed it in. I was thinking of putting a layer of west system over the whole top and painting it white just to clean it up. Will west system be in contact with 4200??
Here are photos:
