Update: not going very well
I should've taken a picture but basically I end up with this ~1 inch section where perfect seating is occurring that is in about the middle of the area on the taper that the prop hub covers. It almost gets kinda polished right there, with only fine barely noticable scores across the marker in other places that I don't think qualifies as being seated right.
My layman's view of the process is that the grit mostly gets squeezed right out of that tight spot, which is where you really need to see some material removed. Getting worried I'm going to f something up if I just keep trying how I'm doing it.
If you asked me last night my response would have been f-this, I was banging the coupler off and bringing it to someone to check the fit & lap it, but after some sleep I'm ordering some actual Prussian Blue and a compound that might be better than this permatex stuff and will have a beer and see what I can see/do first. If nothing else by completely covering the shaft with a potentially better dye I might be able to see better what I'm up against.
