sealaw
I ran into a fellow Fortier 26 owner recently - his boat has a Volvo TAMD41. He told me that he used to run the same prop as we have (Mich. 4 blade 17x18) and got about the same fuel efficiency we currently get (~ 8 gph @ 2750 RPM, pushing @ 16.5 kts).
He recently switched to a deeper pitched prop (I believe he said 19" pitch) and the result was that he cut his fuel consumption in half (!) while achieving the same speed. He didn't mention any change in RPMs for this speed range - but I assume it must change given the deeper pitch.
Does this sound reasonable? Should I consider re-propping? Will my Yanmar/Hurth 1.56 combo tolerate the increased torque? Will the resulting lower RPMs have a negative impact on the way the Yanny runs?
The fuel saving is irresistible - but sounds too good to be true.
Any comments/ideas? Thanks to all...
