General info about down east pricing
tonysmjc
I just finished refitting my 35 Osmond beals she was built in 1997
heres the list of what was done
new factory reman cummins 430 0 hours 2 year warranty pro installed
cabin extended 2.5 feet small dinette added
and closed in port side adding sliding door
aft sliding door
new aluminum frame windows with butal tape 2 open
two coats sprayed on algrip ( pro job indoors) full exterior including the cockpit and inside the cabin ( not repainted down below but that's in good shape
covering boards painted teal with non skid
deck painted 2 part epoxy no skid grey
all hardware removed n re bedded ( no water intrusion anywhere)
totally re wired both 12 volt n 110 (no generator) but she has space and is set up to take one
new bait pump 3700 gph
new 12 volt wash down pump 3700 gph
new buss heater
new wiper
led deck lights
new pitts clutch
new hydraulic wash down pump
new steering ram ( last season)
new hydraulic lines ( most of them some were done last season)
new hydraulic oil cooler
new floscan
new oil change system
fresh bottom paint
2 new 2 x 4 hatches one port one stbd side of the engine for access
brand new bronze 4 blade prop 26 x 28
with spare 25.5 x 26
full electronics garmim gps
northstar 6000 with radar n bottom
fcv 1100 100 watt transducer
2 new vhfs with new digital antennas
pathfinder radar
swivel helm chair re covered and base refreshed n painted
sideband n tuner available not installed n/c
older 8 man raft available needs repack n/c
jim boy life float available n/c
dual anchor spreader
hydrolic hauler
2 x 40 lb anchors and rope 100 foot each new last season
I think that's it
Whats she worth ?
Duke
Rye, NH
Dyer 29
tonysmjc
view pics on face book if your interested
Marilyn jean charters
im not really good at the picture thing
and they are not really needed here im asking that the group give me a best case scenario based on my having told the truth
don't worry about being a wise a## I don't bother me a bit
I just checked you website.
Dam fine looking boat !!
oldshell55
new york
BHM36 , 38’ young bros ,
? if a new auto looses half it's value out the showroom, then what about a boat. you've basically refitted it to new showroom condition, probably better, since it's now got all the bugs out. Value: New replacement / 2 = $? I don't know, gotta start somewhere , check the price of brand new they are quite high
Keelboater
Don't know what she's worth, but I do know that a labor of love must be used to see any kind of payback. Unless the boat was given to you or purchased for pennies on the dollar, it's tough to get the labor back. I hope you are only asking to get an idea of her value, and not walking away from her after all that work. Good luck with her either way. Nice looking rig!
tonysmjc
Just looking to get an idea
I've had her for 9 years and she served me well
I know what I would ask if I was putting her up
I'm just curious as to what people with more
Knowledge in Downeast boats thought
While I've owned her for a while I never followed pricing , value and trends for
De boats
So the threads more out of curiosity than anything
All the labor was done professionally
Except for the 12 volt wiring that I did
All tinned marine boat cable , heat shrink ends and connectors
And any thing below decks was double heat shrink tube over
Heat shrunk connectors
All new panels are blue sea
8675309
Nice boat. I bet she's worth good money. Looks like turn key for a 1997. If you had more pictures it would help. New power helps out a lot.
tonysmjc
im not sure I agree with the labor of love part
if the labor was right and done properly , and you don't over pay for it or over do it ( ie put so much in that its of no real interest to anyone but you)
why should the labour I put in or my shop puts in be worth any less than any other builder
labour of love only comes into play when you customize something so much that it only matters to yourself or you start with a platform that has no real value to start or only has sentimental value like grand dads old no name watch
what does a new 35 ft de with a 3 window deck house rigged similar run these days anyhow?
tonysmjc
im not sure I understand the post OS
but I assume you are asking if im SW boat works
answer NO
im not a boat shop nor am I affiliated with one Im a charter party boat operator the work on my DE was done by Altantic service in rockaway NY
oldshell55
new york
answer NO
you can go to sw and check out pricing on new, used, and kits
tonysmjc
I didn't know anyone posted pricing and equipment like that
thanks
a similar 34 is 198k without electronics , slighlt less power, radar arch and such
so to build mine new as is im guessing 250 260 and a year wait
current value 150 ish ?
oldshell55
new york
thanks
it's a place to start, thinking of my earlier post on auto comparison can't compare a good used boat to a used car, that's only good for 10-15 years . I built my boat in 89' it's worth more today than I put into it. there are a lot of variables. Bet that replacement cost was an eye opener, it was for me! good luck
tonysmjc
Yes an eye opener
In price and in what they provide
Haulers
Bilge pumps
Ect
Looking at what they offered I'm closer to the 36 than the 34
And that's 228 and still missing a lot of what I've already got
I'm not looking to sell her but will be insuring her for
175 because it would cost me at least that to get one close
GOD forbid anything bad happened
tonysmjc
She's wet
Took a short test run today
She's ran well
2000 rpm 15.5
2350 19.5
