- Sep 1, 2011
- Boat Make
Bill, searched everywhere for those little fuel line shut off valves. Any idea where I can purchase them? thanks
You can buy the shut off valves from Seaboard Marine. The priming bulbs work good also during a filter change.
It's my understanding that it should be placed between the fuel tanks and the first stage filter. Tony's set up appears to be 3/8 ID not 1/2" ID? Very difficult to purchase from Tony's shop because they are so busy.
Where was your fuel/air leak? I installed the SB filters and FloScan unit on my 3208 and have a leak somewhere that causes me to either have to prime every overnight start or crank the engine like crazy.
I just upgraded to the bulk seperator only... Was kinda wierd was out for 30 minute and then got an air issue, then never saw it again for hell 50 hours its been fine. Racor has stayed cleaned as well. Wish I had a gauge on the bulk seperator to know if it was dirty or not. I have a couple ideas...
Is the bulk seperator a racor or spin on fleetguard?
If racor you can take out the Tee handle and put a guage in there. That's how the r900 I took out was set up.
