Anyone have green stick dimensions? I am looking for specifically the following
On a 40' stick-
Butt diameter
Top diameter
Butt wall thickness
Approximate taper
is the taper consent or does the taper per foot increase at the top
I don't have the 40, I think mine is 35, but every brand will be different. You can dimensions for the etheridge sticks from alltackle fishing's website. They just resell the etheridge imports.
For my stick, the base section was (roughly) 3.5 inches, but so was the upper joint. It tapered down in the middle, but the ends were about the same diameter. The top joint flare is very strong as a result.
Each of the top two sections more or less tapered uniformly, but again, the top of the middle section flared out a little so they could make it stronger. The very top section is just a straight taper.
Unfortunately, the only accurate dimension you will get is the base. The others you will have to measure.
The pop website may also have dimmensions for their stick. I don't remember.
