Grinders
BentWheel
i Have smoked 3 grinders in the past bunch of months. All new out of the box, dewalt, Bosch, and a new-ish Milwaukie- they all choked doing nothing but sanding! And suffered premature deaths. I have two old Milwaukees that have no business still going but they r the best.
anyone have any better luck with any particular brand/model? (On new perchase)
thank you in advance
Blueff62
Been a welder for a long time. Been though a lot of grinders . Best so far are Metabo.
Gurryman
New Bedford MA
Mark
Nauset 28, Fortier 26
My choice for small grinders has always been Bosch. I regularly blow the brush housing and armature off with compressed air. The metal dust can bridge the gaps in the armature causing a short and premature failure.
winterking
Kodiak AK
Tom
26’ Duffy
xbskt
13 Whaler, 14 Salty Boats, 28 Crowley Beal, 36 Northern Bay. WTF!?!
I have been using an old Porter Cable for years. Long enough that the same unit might be made a lot cheaper in some sad factory offshore now so your results may vary.
Diesel Jerry
Forum Sponsor
Fishinengineer
Suffolk County, NY
Duffy
Have had good luck with Dewalt DWE402. Used exclusively for welding and cutting. Bought this because of the power, it's 11 amps. If you're using a 6 or 7 amp model you might be heating them up too much if you're leaning into them. Most of the welders I run into are using either Dewalt or Metabo. Some of the metabos have a slip clutch for the disc that's a good safety feature if you jam the wheel.
kehoff
Cambridge Maryland
kevin
Wilbur
before it lets the smoke out , shut it down when it starts slowing down , and cool it off or check the brushes , My favorite for heavy work is a huge old black and decker
TAftw
RI
Grinding fiberglass will ruin them also, I take a piece of foam and zip tie it over the intake, I rip it off every week and blow everything out with air. I use Dewalt grinders, it definitely seems to help make them last.
goin4broke
Mystic,CT
Fact is, the CEO’s of all the companies mentioned above can’t maintain their multiple million dollar salaries by selling you just one tool.
I remember in the late 80’s watching the movie Wall Street. The most memorable part was Micheal Douglas playing Gordon Gekko with the infamous Teldar Paper speech. Where he said “greed, for lack of a better word, is good”. There was a time I believed that. Taking something that was mediocre or failing and making a better product.
Ask me now and I’ll tell you the only thing greed is doing now is helping fill land fills.
As an example, when I graduated tech school, my uncle gave me a Milwaukee right angle drill. Used by the way. It weighs about 10 pounds and is most likely older than I am. Aside from replacing brushes, only once. It will chew through anything.
I just realized I sound like my father.
c1steve
The Harbor Freight grinders I have used were terribly out of balance. The vibration was exceedingly uncomfortable.
Aloop
What ever you buy from Harbor Freight get the lifetime warranty version.
SeacoastNH
We run Hilti grinders in our fabrication shop. They get cleaned periodically. I like the idea of the foam ziptied that was mentioned above.
Benny
I get a lot longer session out of grinder (before it overheats) when I use a big one with an adjustable speed. A descent 7” with variable speed is great. You don’t need to be spinning a million RPM’s, I run it half speed with a big aggressive disc and it eats everything in its path.
I prefer a variable speed for wire wheels too, I’m sure we’ve all seen one of those get away from you and look like a loose fire hose. I run them all as low speed as will get the job done efficiently.
leaky
The issue I see with a lot of tools is just simply overheating. Why this wasn't a problem w/ 20+ year old Milwaukee grinders and is now - obviously some quality has been lost. Brushless motors do help reduce heat & I see they now make them in corded models - that likely is a good feature to seek.
With drills, if there's a lot to do, I setup 2 for what I'm doing and I switch back & forth. Same w/ geared 110v sanders. This way I'm not smoking them. I've never noted such problems w/ a grinder but I'd do the same if they seemed to be getting hot.
Members online
