kmac
What are the engine options for an Osmond Beal 29? I would be looking for a 16 to 18 knot cruise. Top end not that important but efficiency is. Diesel only of course.
Will it be a new build or older boat and is it for commercial use or rec.
I was close to building out a new 29 H&H last summer. I was going to install a QSB 5.9 480.
In actuality a QSB 330 or 380 would be perfect for the 29 H&H.
The QSB is about 600 pounds heavier than the Yanmar. Isn't 1500lbs a little too heave for that hull?
Yanmar 6BY3-260 hp...or the 315 hp both are nice motors...I have two friends with the H&H 27 and 29's.....they are commercially used and have cummins motors
I am in the process of repowering my 29 now. I am installing a yanmar 315 hp with a 2.5 to 1 gear and a 4B 22x22 prop, Looking at A prop calculator I am hoping for a 17 to 19 knot cruise @10 to 12 gallons an hour 20+ WOT
I do not know much about the new BY motors. The 315 Yanmar would be ideal however it is not longer being made. If she was my build I would go with a 6LY3-UTP @ 380 HP Yanmar. A great power planet. Weight is640 lbs. less the gear. I would also use a 2:0 ZF85A transmission with a total weight of 730 lbs.
If this is too much power for you my next choice is the 330 HP Cummins.
Good luck with your new build.
The weight of a 6LY3-UTP is 1411lbs without gear. Where did you come up with 640lbs?
Well only my opinion with my #s. The BY is a real sewing machine, She come it at 4000 RPMs. They are velvet smooth & quiet. Do not let 4000 RPMs scare you. These new diesel are different animals that years ago.
260 BY would need:
2:5 gearing
with a 21 X 20 or 20 X 20 Dyna Quad
WOT throttle performance @ 4000 RPMs would be 21 Knots
Max Cruising RPM of 3600 would be 19 knots.
1.5 shafting is plenty.
Thanks for the response.
What about a 4LHA-STP 240HP at 902lbs with gear? What gear, prop, and speeds?
You are right, I am a little concerned with a 4000RPM diesel. The 4LHA-STP is a 3300RPM engine and also more displacement than the BY.
