Head is Dead
Discussion in 'Marine Electrical / Electronics' started by Cdux, Nov 17, 2018.
  1. Cdux
    Cdux Senior Member
    Mar 20, 2014
    282
    374
    So. Me
    So the head shit the bed the other day. Its raritan thats only a season and a half old. Been sounding a little queer for the past month.
    Found all this build up either side of the motor housing. Any thoughts what causing this; perhaps improperly sealed at the factory? 20181117_132212.jpg
    Cdux,
  2. EZ1
    EZ1 Senior Member
    Aug 16, 2018
    105
    44
    boat builder
    Marina del Rey
    Freya
    EZ1,
  3. Cdux
    Cdux Senior Member
    Mar 20, 2014
    282
    374
    So. Me
    In what sense? How much preventitive maintenance is there on a supposedly sealed electric motor?
    As far as appearance yes I could take apart the fairings each trip and scrub down the entire unit, but a heavy dosing of bleach keeps the odor down till the choker valve get replaced mid season.
    Cdux,
  4. EZ1
    EZ1 Senior Member
    Aug 16, 2018
    105
    44
    boat builder
    Marina del Rey
    Freya
    A thorough cleaning once in awhile will keep the odor down even better, and the head will not wind up looking like that after such a short time in service.
    EZ1,
  5. captjohn
    captjohn Captain
    Apr 12, 2013
    551
    176
    Seaford, NY
    Henriques
    Bad aim!!
    Keelboater likes this.
  6. Cdux
    Cdux Senior Member
    Mar 20, 2014
    282
    374
    So. Me
    It gets a lot of use, 15-25 trips a month in season with 10-15 guys, most enjoying a few (to a lot) of adult beverages
    Cdux,
    captjohn and Schomakr like this.
  7. EZ1
    EZ1 Senior Member
    Aug 16, 2018
    105
    44
    boat builder
    Marina del Rey
    Freya
    Then it should be cleaned every day.
    EZ1,
  8. F/V First Team
    F/V First Team Captain
    6,085
    2,358
    Everyone sits on my boat, just a suggestion
    ben2go, Toolate and JimRP31 like this.
  9. Pedlyr
    Pedlyr Senior Member
    Aug 31, 2011
    430
    102
    Port Engineer
    Southern RI
    Big fan of the bucket myself
    restless likes this.
  10. chortle
    chortle Captain
    Mar 7, 2012
    769
    325
    retired
    Annapolis, MD
    What kind of beer are they drinking :) Guinness or Coors light?
    So did the motor fail? Maybe this is a boat system electrical issue? I would check other electrical components on the boat for accelerated corrosion. New marina? New next door neighbor? How's the prop zinc look? Is the ground connected to the main ships ground or something else? Do you plug into shore power? The ground wire has a funky pinkish color which is often due to electrolysis. It doesn't look so much like pee splash corrosion (acidic) or excessive bleach corrosion (base) as much as electrical imbalance attacking the weakest links (lots of corrosion on the end caps of the motor but nothing on the main case.) Pee and bleach might do this after several years but after one year is unusual. Something is making this happen quicker than it should. What happened to the previous head?
  11. mike@mpi
    mike@mpi Senior Member
    Sep 1, 2013
    268
    96
    stevensville, md.
    26 JC
    Is it a salt water head? To me it looks like seawater leaked down from that flange above the motor and attacked the aluminum motor end castings. One of my customers has an old Tiara with one fresh water vacuflush head and one Raritan salt water head in the guest cabin. Though the fresh water head gets a hundred times the use, it looks and works OK. The salt water head looks like a haunted house candle.
  12. cptnpete
    cptnpete Senior Member
    Oct 18, 2011
    221
    51
    Scituate MA
    Morton & Hersloff/Webbers Cove 40, Forest Johnson Prowler 32 (for sale)
    I have the same head. Looks like flange of bowl base may be leaking as noted above. If not sure is nasty looking. Other thing I notice, mine only has two wires, plus and neg. Looks like you have two wires attached to neg terminal. Not sure what additional wire would be for.
  13. the_Bartender
    the_Bartender Member
    Jan 20, 2017
    98
    52
    Former Merchant Mariner, Now Commercial Fishing
    Lower Chesapeake Bay/Atlantic Ocean
    35 Bruno
    The second, (Yellow collar) wire on the negative terminal of the head motor is probably a grounding, (bonding) wire that should be on the motor body and NOT the negative terminal.
    yanmar likes this.
  14. Toolate
    Toolate Captain
    5,389
    1,467
    Building contractor
    I would look at where ground is connected and also ask-
    Are you feeding this with salt water? Maybe just salt water dripping all over it and sitting on the steel/white paint is all.
  15. BlueMack
    BlueMack Senior Member
    Oct 14, 2014
    427
    156
    New Hampshire
    Bruno & Stillman 35
    With that amount of use i would say you got your monies worth, replace with a higher end or better protected model.
  16. cptnpete
    Oct 18, 2011
    221
    51
    Scituate MA
    When I got my boat in April the seller stated the forward head motor needed replacing. They aren't cheap. The motor buzzed but did not spin. It turned out it was a rusted bearing. $8 bucks and a couple of $20 cuss words later and we were back in business.
  17. Toolate
    Toolate Captain
    5,389
    1,467
    Building contractor
    Been using Raritan Marine Elegance head- full china bowl and motor is easily accessed. Kept up with my kids for 5 years now on 2 boats.
  18. cptnpete
    Oct 18, 2011
    221
    51
    Scituate MA
    We have Raritan Crown model which looks like OP's. They are 12V raw water heads that macerate. Seem very robust and powerful. Easy to replace/disassemble components. After having used only manual heads before I have become a believer.
    If that extra wire on the neg is for bonding as suggested above, why would there even be a need for bonding the head?
  19. the_Bartender
    Jan 20, 2017
    98
    52
    35 Bruno
    Because it has electricity and salt water running through it. And parts made of various metals.
  20. goin4broke
    goin4broke Captain
    Aug 28, 2015
    995
    359
    Electrician
    Mystic,CT
    Bought one a while ago for the TJ. Not sure if they “make em’ like they used to” but, we’ll see.
    Toolate likes this.
