High water float switch location
How high or low in your bilge is your switch mounted ???
I'm thinking of glassing a piece of Coosa across my keel tunnel, a bit in front of my shaft seal.
Thinking this will give me a good height for switch and give me a location to mount mascerator pump for livewell pump out in front of the livewell tank.
Not sure though about mounting over shaft.
Thoughts or suggestions ???
Curmudgeon
Low
Mine is barely 6" up from bottom of the keel. Barely higher than my higher (bigger pump) bilge pump switch. If you ever have a problem it is better to know early as possible.
Billyclub
Scarborough, Maine
A little higher and just forward of bilge pump. This will keep the pump from sucking air needlessly. Also if the switch is mounted to low it will cause the switch and pump to cycle causing premature burn out because the pump is mounted at the same level as the switch. im talking just a 1/2- 1 inch above
tomy
36 Wayne Beal
hey Ronny. make sure you get a bell or loud claxton type sound producing device to go along with it. call me and you can see / hear mine. believe me..you want loud if that goes off.:D( especialiy up in yr tower)
Ronnie,
Rule has a high frequency ear piercing alarm.
I was "measuring up" a DE last weekend and when I got out of my car in the parking lot my "ears were ringing" from "something".
At 1st I thought it was a transformer or something.
When I got on the boat I knew it was "something" on the boat.
Not knowing the boat I had to hunt around and it was the Rule alarm.
I called the owner and he could hear it as I was talking to him.
He had a crew member install the alarm day before and it had rained heavy overnight.
FWIW,
Bill D
I guess the lower the better so long as its not so lot it's coming on all the time.
Getting down low enough in my keel to glue or glass a mount should be a lot of fun.
Not like I got a big engine room like lots of bigger downeasters.
I'll get it done, its about time my 12 or 15 year old sons learn a bit about fiberglass work anyway.
My 12 year old is a small kid for his age which should be a bonus :rolleyes:
GLA
my high water alarm is just above my second bilge pump, which is just above the primary bilge pump. the second bilge pump is ported so that if it goes off the water shoots out of a thru hull mounted at the top of the gunnel outside the boat so everyone can see it go off.
captchuck
Long Island
26' Seaway
Ronnie,
FWIW,
Bill D
Bill can you elabrate on the alarm?
Was it installed correctly and they intentionally let it go off etc... I like the sounds of a basic alarm like that vs the alarms that require an internet hub that I have read of.
Thought it through some more.
I'll some how manage to glass a block to mount the float switch down in the keel, low but not too low and I'll use that switch off the alarm/buzzer that I plan to mount at the helm and I'll wire it to a 2nd bilge pump for the keel. Was planning to add a 2nd bilge pump down there anyway.
Communist part of NJ
Bertram 33SF
you know an easy way to you can bend up a piece of aluminum in a Z, mount it up on the engine mount. Tap it and use machine screws for the float. I would presume you have enough access for that no ?
tomy
36 Wayne Beal
Ronnie, and everyone. Make sure you install a light along with sound producing thingy......Coast Guard requirement you know.:rolleyes:
Downeastless
What is sad is how many boats that they are located in an area by the time it gets there, its just to late almost. I have to go into mine to put in a new pump. Right above the second pump as said here is best.
Gets me going about DE Keels. Why do I think that if we just glassed them over somehow under the engine pan it would be a great place to some weird tank, like an emergency water tan, put a bladder in it to make it a potable tank or somethnig. Of course would be a nightmare down the road to deal with if it failed but just think. Just dreaming now...
Live Wire
Edgartown,Martha's Vineyard
38'wesmac
Add strobe
I mounted bell for high water alarm, but also installed 12 volt orange lens strobe light that next to door with "High Water Alarm" and my cell phone # on a label. Hoping that if a high water alarm exist and not around, would get someone's attention and be notified.
