scallywag
Hey guys could use some help. Just lauched the boat, the diesel fired right up but with a noise. Electric clutch for the hydraulic pump is dragging un engaged. Noise goes away when engaged. Slight evidense of metal dust. I figure bearing in clutch assembly is bad. Anyway I need to investigate serial numbers on pump but I think it is a Greson pump and a Pitts clutch assembly. This system is for a Hydraulic anchor windless system. I have never had to service the Hydraulics before and could use a good source for parts. I am sure some of you deal with hydraulics on a regular basis. Any advice would be appreciated. May not get back to the computer until tomorrow. Thanks!
