backman
I have a Hydroslave pump and hydraulic steering system off the PTO pulley on my engine. It has a cooler with its own throughhull and scoop.
Questions:
1. How much HP does this take from my engine output?
2. Is the load constant or does it increase w/ RPM's or with the rudder being turned?
3. I measure the copper pipes connected to the pump and reservoir at 140-150 degrees F back at the dock. Is this "normal" and if so what is abnormal?
4. I hear a pft pft pft from the system at idle; there is a slight leak/drip only at the junction of pump and stainless block on top of the pump. Is this telling me I have air in th system?
Questions:
