TCL
- Jan 29, 2014
- Location
- Annapolis MD, formerly Huntington NY
- Boat Make
- Sabre 36 The Captain's Lady
The reason for the alignment check is that while at idle I hit a sand bar? The Port engine stalled. Prior to this event the Port propel shaft was fairly easy to rotate by hand, after the sand bar hit it is slightly more difficult to turn by hand…but not too bad.
Are there any special procedures to follow with a Dripless? Boat is currently on the hard, but planning on doing the alignment in the water this spring…or should I do a pre-alignment while on the hard?
I’m thinking that once the flange bolts are loosened I’ll be able to slide the shaft aft a few thousands of an inch in order to get a feeler gage in there.
Am I missing anything? I’m not planning on loosen the PSS shaft collar.
