Increasing the Size of My Rudder
Discussion in 'Downeast Boat NEWBIES' started by tro7278, Jul 15, 2019.
  1. tro7278
    tro7278 Member
    Mar 2, 2012
    51
    I want to increase the size of my rudder and wanted to experiment on adding to it. Has anybody done this and if yes what are your suggestions. The current rudder is Bronze or Nibril not sure. It currently has two holes for Zincs in it so I could conceivably bold a section to it. I want to try to different shapes and sizes to see if I can come up with a bit less wandering in the steering.
    Tim,
  2. powderpro
    powderpro Captain
    Dec 3, 2011
    2,995
    2,138
    The Ocean
    O'Neil
    How fast is your cruise? Bolting on additional rudder surface doesn’t sound like a good idea.
  3. tro7278
    tro7278 Member
    Mar 2, 2012
    51
    Right around 19 knots. I will admit I have no clue what I am up to and am totally open to listening and understanding what I should or should not try given peoples knowledge and experience.
    To explain it better regardless of head sea or following sea flat as a mill pond etc. The boat like to wander and it always seems I am have to make course corrections. Not huge amounts, the auto pilot does a decent job but it also is constantly adjusting. I could be doing 15 knots or 19 knots it still likes to do it.
    The truth be told it could be the hull design and I am where I am.
    Tim
  4. Blitzen
    Blitzen Captain
    3,733
    2,195
    Ex Merchant Mariner
    Normally as speed increases the less rudder that is needed, so as speed increases the smaller the rudder.
    Sounds more like you may have a problem with the steering system.
  5. Ol Gilnetter
    Ol Gilnetter Senior Member
    Apr 26, 2013
    365
    165
    You could also have hull restrictions to your speed. Meaning your hull may not like the speed. It may have some extent of bow steer that may not be something you will overcome. What hull? Have you opened up hatches to watch the rudder/steering hardware at speed to see if you have anything "moving" when you are not intentionally moving the steering wheel. At 19 knots you don't need a lot of movement to get a course change so look closely.
  6. Genius
    2,504
    1,244
    Any pictures of the boat and rudder? Weight distribution can cause wandering issues also.
  7. Cool Boat
    Cool Boat Member
    Jul 6, 2018
    49
    16
    Hydraulic steering? I wonder if the autopilot is pumping fluid on the same side of the cylinder piston which is bypassing fluid/leaking down (maybe observe it). I had a previous boat that was a bear to bleed the air out too. Air being compressible caused lots of handling problems on that boat until we spent a hot summer day thoroughly bleeding it. Is there excessive wear or looseness in the linkage? We also have a steel trawler which had the Furuno rudder angle sensor go bad a few years ago. The intermittent problem cleared up after sensor replacement. Professional Boatbuilder magazine had a good article on steering systems a few months back too. Good luck.
