backman
Need some ideas and help in the best way to approach installing the LD Marine roof mounts
The mount bases are about 8" square and I have 5" between the handrail and the outside of the hardtop.
The handrail is PVC, so cutting it is a bad idea; the backing plate aft of the handrail is for the rod holders mounted off the roof.
Mounting inside the handrail is possible but I'll end up giving up 12-18" of spread width on either side.
Suggestions?
Suggestions?
