exiledgator
- Jun 5, 2012
I'm contemplating a used ~20' center cockpit DE boat and I'm hoping to tap the wisdom of this board to see if:
1.) This would be a good boat for my intended use?
2.) How much should I expect to spend to be up and running?
I realize these questions are unanswerable without more info, so here we go:
Intended uses:
We're looking to buy a boat in about 2 years to take our kids (that will be 5.5 and 3.5 by then) out into eastern Casco Bay (ME) and possible trailer into other ME bays. We will be day tripping to islands and tent camping on islands. Ideally - I'd also like to pull some lobster pots (rec license) with the same boat.
With that in mind, here's my wish list: I want a boat that is sea kindly, sea(bay)worthy, fairly dry, shallow draft for coves and rivers, relatively fuel efficient, able to carry a family of 4 and camping gear / or 6 - 8 passengers, can be used to pull pots.
I've owned a half dozen boats in my life - up to a 30' cruising sloop (I'm a life-long sailer) - so I recognize that everything is a trade off in boats. I understand that I may not find a boat in the size and price I want, that will do all the things I want to do. But that's why I'm here asking about DEs.
How many of my wishes would come true in a ~20' DE?
How much should I expect?
Again, I've owned and vigilantly maintained many boats (have yet to pay anyone to work on a boat of mine - except for marine diesel) so I'm aware that there's "nothing more expensive than a cheap boat". I've seen some DE boats in the 18'-22' range on craigslist from $6K (obviously needing lots of work) on up. I don't want to bring an older boat up to Bristol condition - I just want to make it solid, clean, and serviceable. Can this be done under $15K? Under $10K?
Thanks in advance!
Intended uses:
Thanks in advance!
