chasintail
had oil coming out wet exhaust , black smoke , seemed to idle fine after, ran back at about 1400 rpm no oil, no black smoke . what do you think ? THANK YOU bouncing pressure gauge also
Hello, how is the oil level? Are you sure it is oil and not fuel? Have you checked the turbo charger for a shaft failure or seal failure, see if the impeller and shaft are all afloat with too much clearance where the fins could contact the housing. The bouncing pressure gauge could happen if you are low on oil or filling with fuel and diluting the oil so that the viscosity changes and becomes too thin. Let me know. I have a dealer in S. Dennis who could come and check it out (S&J Exco), one in Charlestown MA (Steve's Shop) and one in Fairhaven (Yankee Marine Diesel).had oil coming out wet exhaust , black smoke , seemed to idle fine after, ran back at about 1400 rpm no oil, no black smoke . what do you think ? THANK YOU bouncing pressure gauge also
shaft failure or seal or both, afloat too much clearance, fin contact. took turbo out trying to locate turbo. iveco 8061 srm27 . 10 ser no 384296 . The turbo I took out is a kkk k27 81 10541 I believe this turbo is rated at 250 hp i think this was a replacement . how could i check to see if this is the right turbo for this motor or not . thanks RonHello, how is the oil level? Are you sure it is oil and not fuel? Have you checked the turbo charger for a shaft failure or seal failure, see if the impeller and shaft are all afloat with too much clearance where the fins could contact the housing. The bouncing pressure gauge could happen if you are low on oil or filling with fuel and diluting the oil so that the viscosity changes and becomes too thin. Let me know. I have a dealer in S. Dennis who could come and check it out (S&J Exco), one in Charlestown MA (Steve's Shop) and one in Fairhaven (Yankee Marine Diesel).
At your service for more questions.
Peter
Hello Ron,shaft failure or seal or both, afloat too much clearance, fin contact. took turbo out trying to locate turbo. iveco 8061 srm27 . 10 ser no 384296 . The turbo I took out is a kkk k27 81 10541 I believe this turbo is rated at 250 hp i think this was a replacement . how could i check to see if this is the right turbo for this motor or not . thanks Ron
