Lap Fitting Props
tunafishhkg
Cape Cod MA/Hong Kong SAR
35 Duffy
Great U-tube vid on "lap Fitting Props" as well as "Just got shafted", Great info on props and shafts! KEF791's Channel - YouTube Disclaimer: Kieth is one of my best friends but that aside, one talented machinist which is how we met when I hit Bull Rock:eek:
Downeastless
Does great work, helped me out several times and will use him for a couple projects when I get home!
tunafishhkg
35 Duffy
I once helped some one align his shaft on a 36 WB and had to add 1.5" to the rear mount to get it even close to alignment and that was after they replaced the trans because the housing broke at the output shaft. They said that the misalignment had nothing to do with it:eek: Kieth will measure the runout then calculate how many turns on the mount it needs to align instead of my way of trial and error which sure helps if in a tight spot. Kieth is also no slouch on the rod, fought three fish in 3 1/2 hrs.
